Replacing (lower link) stabilizer brackets
   / Replacing (lower link) stabilizer brackets #1
Pabco
Meadow Vista, CA
Kubota B2650 / FEL LA534 / BH77 BH
Has anyone taken off or replaced the "U" shaped bracket stabilizers that connect to the lower (3-point) link to the stabilizers? I bent one and need to replace it. However, with a BH frame it looks like the lower link won't slide out. Is it possible to loosen the center bolt and slide the lower link enough to one side to slide off the bracket, and then reverse for the other side? Thanks for your help.
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
2015 Ford Fusion (A50324)
2015 Ford Fusion...
2020 John Deere 160G Excavator (A47384)
2020 John Deere...
1993 Barrett Gooseneck Livestock Trailer (A50514)
1993 Barrett...
CASE IH 2412 - 12R CORN HEAD (A51243)
CASE IH 2412 - 12R...
