Replacing live PTO lever and side plate on Massey 135.
   / Replacing live PTO lever and side plate on Massey 135. #1
Dave Davis
Somerset, Ky
Massey Ferguson 135
My first transmission fluid change and filter check. Is aligning the linkage a problem after cleaning the filter? If I leave the PTO lever in same position when replacing, how will I know if it is correct? Massey mechanic gave me the PTO shaft check routine... Is there any visual I can go by while replacing the rod that engages the gear?
   / Replacing live PTO lever and side plate on Massey 135. #2
G'day Dave if you have the lever in the same spot then you shouldn't have any trouble it is a pretty positive fit
Jon
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2018 CATERPILLAR 336FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
UNUSED FUTURE MINI EXCAVATOR HYD 18" AUGER (A51244)
UNUSED FUTURE MINI...
40' CONTAINER (A51244)
