Loader Replacing hydraulic line on BX24 loader
   / Replacing hydraulic line on BX24 loader #1
easternhunter
Charleston, WV
Kubota BX24
Guys,
My BX24 has sprung a little hydraulic leak on the long line on the driver's right side of the loader.
What is the appropriate procedure for removing the line so I can have the fittings redone into a new hose?
Thank you!
Mike
   / Replacing hydraulic line on BX24 loader #2
Make sure the tractor is off, bucket on ground. Relieve all hydraulic pressure off the bucket by moving the valve controls in all directions a couple times. Get an open end box wrench that securely fits the fitting. Righty tighty -- lefty loosey. Grab a rag to sop up whatever comes out of the hose and cylinder.
Either take it to a hydraulic shop (heavy duty truck shop) or most Kubota dealers will have the equipment on site to make custom hoses.
After you get one made, installing it is the same as it came off. After installing, fully cycle the hydraulics several times, then put the hydraulics under some stress (in your case, you should be able to pick up the front end). Keep it there for about a minute. Then let the tractor down, fully relieve all hydraulic pressure, then check for leaks.
NEVER EVER grab a hydraulic hose while the machine is on or if the hydraulics are under pressure! If you need to check it while it is under pressure, use a piece of cardboard!
If all is good, then you are all set.
Hint/Tip: If it is a weird angle (ie: custom fitting), most likely a simple 45 degree will work. Like say on the loader controls or off a cylinder. Rarely do I run into where I absolutely need a factory specific hose. Another tip, you can always go a bit larger on the hose diameter -- never smaller.
Diesel85 ...
Thank you!
The front end loader hoses go to a block that has quick disconnects for 4 lines. Which are for the right side cylinder. I assume that after relieving the pressure in the system it is wise to use the correct side disconnects before cracking the fittings on the hoses. Correct?
Thanks again!
Mike
   / Replacing hydraulic line on BX24 loader #4
Nope. Not necessary. By wiggling/cycling the loader control valve through all functions is more than enough.
197637 (A50459)
197637 (A50459)
2023 BOBCAT 776R SERIES SKID STEER (A51242)
2023 BOBCAT 776R...
2022 KUBOTA KX040-4 EXCAVATOR (A51242)
2022 KUBOTA...
3 Drawer Office Desk (A49462)
3 Drawer Office...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2023 JOHN DEERE 333G SKID STEER (A51242)
2023 JOHN DEERE...
