Replacing F-150 serpentine belt.
   / Replacing F-150 serpentine belt. #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I had my '03 F-150 at the oil change place today and they mentioned that the serpentine belt had a nick in it. As you probably know, these places always find something that they want to fix. I asked them to mark it and told them I'd look at it. Sure enough there is a little (tiny) nick in the outside edge (facing me when I look under the hood). It is maybe a few mm wide and is not full thickness involving the top edge (the smooth side, the 'bottom' edge is grooved).
I think this belt is original so it has close to 60k miles on it. The nick is so small I'm inclined to ignore it....but that may not be wise. I just don't know.
How hard is it to replace one of these? It looks like I'll have to pull some stuff out to get to it like the fan shroud and some other junk. I've replaced all sorts of belts on all sorts of other vehicles but have never messed with one of these serpentine deals. Are there any special pitfalls, special tools or special warnings I need to know about? Anything peculiar about the F-150 .....this is the 5.4l v-8. I've looked at the routing diagram for this belt and it is 'serpentine' but not as convoluted as some I've seen.
Any advice would be appreciated.
   / Replacing F-150 serpentine belt. #2
If it's like my 2001 F150 it's a snap. All I need is one wrench to put on the belt tensioner to put slack in the belt and remove the old belt and thread it around everything and reinstall the new belt the same way. No parts removals, very easy.
   / Replacing F-150 serpentine belt. #3
Make sure to check the price online with a couple places. A belt like that could run from $35-80 depending upon where you buy it.
NAPA, Autozone, Pep boys, etc
   / Replacing F-150 serpentine belt. #4
Some are so easy to change and others, well!!!:D
It took me two hours to convince myself the motor mount bracket had to come to change the belt a a 93 Grand Am.:( :(
   / Replacing F-150 serpentine belt. #5
George, the good news on the serpentine belts is that you don't have to actually loosen anything with a wrench, then pry it back out and sometimes just guess at how much tension to hold on it while you tighten a bolt. Instead, you have a spring loaded automatic tensioner so you need one wrench to pull against that spring.
The bad news is that some are not too hard to do while others almost require a second person; one to pull and hold the tensioner while the other puts the belt in all the right pulleys.
In the Fall of '91, I had to put two serpentine belts on the 460 Ford engine in my motorhome. I was able to lay on my back underneath, get my wrench on one tensioner, then the other, attempt to chin myself with one hand while putting the belt on the pulleys with the other hand. I got the job done by myself, but a few years later, my brother (who had been a professional mechanic a good part of his life) finally gave up and went and got help when a belt broke on his motorhome with the same engine.
And the last one I had to do myself was on a 3/4 ton Chevy van with the 350 V-8 and two of us (the other one being a niece's husband who was a professional mechanic) finally go it on there. I don't think either of us would have ever succeeded alone.
On the other hand, I've changed one on a Ford pickup and one on a Chevy pickup with no problem at all.:rolleyes:
   / Replacing F-150 serpentine belt. #6
Make a diagram of the belt around the pulleys before you remove it, so you get it back the way it needs to be. Some vehicles have a diagram on the schroud.
   / Replacing F-150 serpentine belt. #7
There should be a diagram of the belt layout on the radiator top cover.
   / Replacing F-150 serpentine belt. #8
George,
I just had my changed on the F350. The belt looked good to me and the best I could tell it likely had another 30-50K on it. I'm pretty sure I had it changed early per the manual. Figured if I got 95,000ish miles on it I got my money's worth. I have lost an old style belt and the truck drive 70ish miles per day plus two 1,300 mile trips a year. Tain't worth being on the side of the road.
The old belt is sitting under the back seat as a spare. I don't think its a big effort to change on my truck and the cost from the mechanic was cheap. I can't remember the price but I was pleasently suprised how little it cost for a new belt to be put in.
To put it another way, it was less to put on a new belt than to get the truck towed. :eek::D
Later,
Dan
   / Replacing F-150 serpentine belt. #9
I got the belt for my wife's F-150 from Wal-Mart. Was pretty cheap as I recall. I managed to do it by myself with no problem in about 15 minutes.( a good portion of that staring at everything before I pulled it out, so I would be sure and put it back right the first time). Mine has a diagram under the hood for reference. It would have been a little easier/faster if I had someone to hold the wrench on the tensioner back, but was not really a big deal. I had a stick slide up the belt on and F-250 and flip it off once. 3 guys, a cresent wrench, the diagram, and it was almost dark. It ony took 2 tries to get it then.:) Sometimes too much help is worse than none.;)
Thanks for the help guys. I'll give it a try. I can get some help from a pretty fair mechanic this weekend. It looks like a Gates belt for this truck will run about $30.
2012 MACK GU (GRANITE) DAY CAB (A54607)
2012 MACK GU...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2002 PITTS 102" X 35' LOWBOY TRAILER (A51406)
2002 PITTS 102" X...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
HANGCHA CPCD25-XW98C-RT4 STRAIGHT MAST FORKLIFT (A51406)
HANGCHA...
