replacing cam also valve springs?
   / replacing cam also valve springs? #1
weeder
Tuscola Illinois
John Deere 425 lawn tractor
I saw where when you are replacing the plastic gear cam on a 425 that you need to go to a different valve spring? Is this the case? What are they heavier and can take more force due to a steel gear?
Your thoughts on this
Thanks weeder
   / replacing cam also valve springs? #2
Making a new thread here?
Well I didn't know if to put it on the other thread or start a new one? Sorry if I messed up? I can delete it.
   / replacing cam also valve springs? #4
As long as you're in there and doing the work, yes ---- springs, tappets and push rods. Not a lot of $ ---------
What kind of tool do you guys use in holding the small square bolt on the rocker arms when adjusting the valves? It would take a very small crescent wrench or a pair of needle nose pliers just your thoughts?
Thanks weeder
   / replacing cam also valve springs? #6
Thanks weeder
Sears used to sell "Tappet Wrenches" singular or in a set. You may check and see if they still offer them. Tappet wrenches look like regular wrenches but are very thin. Craftsman.com. Got a grinder and a old wrench in the size needed, grind the sides off.
   / replacing cam also valve springs? #7
Been a while since I did it but I think I just used a metric wrench. Don't recall needed to do or use anything special. Pretty straight forward: Loosen nut. Adjust gap. Tighten nut. Recheck gap.
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
71058 (A49346)
71058 (A49346)
