replacing brakes on a 1943 m farmall
   / replacing brakes on a 1943 m farmall #1
pintail
chadron, ne
M FARMALL, WD ALLIS
i have to replace the brakes on my tractor. i first tryed to adjust them. i screwed in the bottom set screw first down tight and then back it out a half turn. that worked for the rh brake. is there a set screw on the bottom for the left hand brake. their is a hole their but no set screw. also my book shows 2 ea brake compressor springs for adjustment but i only see the one??. is their a web site that will give you step by step instructions for removing/replacing. sure could use some help guys. thanks
stupid me i found the lh brake compression spring, where else but on the lh side. adjusted it and helped some but think the bands are wore out
   / replacing brakes on a 1943 m farmall #3
The H and M brakes are simple to change. Just take the covers and fulcrum levers off and the bands slip off the drum. Used to be you could by new lining material & rivets and reline them yourself
thanks junk man. appreciate your reply
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
2018 Regal 29OBX 29ft Yacht with 34ft Trailer (A51694)
2018 Regal 29OBX...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2008 Toyota Tundra Crew Cab Pickup Truck (A51692)
2008 Toyota Tundra...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
