Mowing Replacing Bearings in Ford 908 Rotary Cutter
   / Replacing Bearings in Ford 908 Rotary Cutter #1
Beamer63
Altoona, IA
Ford 2000 1969
I have a Ford 908 Rotary Cutter that squeals when rotating. I am thinking bearings so I took the gear box off and took it apart. The bearings that I can see look good but there is one in the shaft just after the slip clutch that I cannot see and it seems to growl when I rotate it. The big question is does anybody have some good advice on how to get the bearings out of this thing? There are apparently some snap rings in line. I am wondering if they have to come off first before I can force the bearings out. The following link is a cut away of the unit. Thanks in advance for any help as I am somewhat mechanically challenged when it comes to this proceedure.
New Holland 22-195 FORD FRAME A. SERIES 908 ROTARY CUTTER
18005 (A51691)
18005 (A51691)
2007 Toyota Camry Sedan (A50324)
2007 Toyota Camry...
Kubota L3130 Compact Tractor (RIDE AND DRIVE) (A50774)
Kubota L3130...
40' Sea Container (A50774)
40' Sea Container...
Portable Creep Feeder with Gates (A50515)
Portable Creep...
UNUSED MOWERKING QUICK ATTACH 72" ANGLE BROOM (A51244)
UNUSED MOWERKING...
