bdhsfz6
Elite Member
- Joined
- Apr 11, 2015
- Messages
- 3,074
- Location
- Northeastern Pennsylvania
- Tractor
- Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
I'm thinking of replacing my 46 year-old Weil McClain oil furnace. It is still fully functional with no leakage, but I'm concerned about how much longer it will remain that way. I burned wood and coal for most of those 46 years and the furnace was used as a backup, as well as to heat domestic hot water. It was turned off during the summer months when I switched to an electric hot water heater.
I no longer burn coal or wood and am now relying on the old furnace as my primary source of heat. Since it will now be used full time, I'm also concerned about it's relatively low inefficiency rating.
I could replace the burner with a higher efficiency unit but then there is still the aging water jacket to worry about. I chose Weil McClain in 1979 when I built the house for it's excellent longevity rating but I think 45 years is pushing it a bit. I could wait until it breaks down completely but it will likely happen in the middle of winter and I would have no heat source for the duration of the replacement project. To me, it makes sense to pre-emptively do the work during the summer months and also while I'm still able to do the work myself.
There is a confusing array of replacement options available and I'm not sure which way to go at this point. These new high efficiency oil burners that use a 4" PVC vent look interesting, but I don't know much about them. I want to stick with oil since I also use heating oil in my tractors. I have no propane on site and converting would add more expense. Electric heat pump mini splits aren't really an option around here due to our cold climate. People I know who use them here aren't happy with their cold weather performance and wind up supplementing with radiant electric units.
Thanks in advance for any ideas, suggestions or comments.
