Replacing a wheel motor - need to prime it?
   / Replacing a wheel motor - need to prime it? #1
lhfarm
Veteran Member
Central Indiana
NH TC40DA
I've spent a couple of months working on my ZTR (http://www.tractorbynet.com/forums/lawn-garden/151256-pump-fix-snapper-simplicity-mf.html ) and have a replacement wheel motor on the way. I think I damaged the wheel motor when the pump failed and I drove it into the garage. So I want to be careful when I install the new motor.
What do I need to do when I install the motor? Do I fill the hoses with fluid? Do I attempt to spin the wheel by hand to prime it?
Any advice appreicated. Thanks!
   / Replacing a wheel motor - need to prime it? #2
Yes, go ahead and prime the motor. You can spin it by hand until you fill it. The motor will not turn under power, until it receives fluid anyway. The pump is the main thing. Always prime the pump. It only takes a few seconds of ruining before it destroys itself.
Jack the wheels off the ground while testing.
There may be small bits and particles from the pump, still in the hose. You could pull a lint free rag through the hose to help clean them out or flush the hoses with water and air.
They do make high pressure filters, but it would get expensive to install 4 of them.
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2021 TAKEUCHI TL6R SKID STEER (A51242)
2021 TAKEUCHI TL6R...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2015 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2018 ISUZU FTR 24FT BOX TRUCK (A51222)
2018 ISUZU FTR...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2019 KENWORTH T680...
