replacing a pitman stick on a John Deere 8w
   / replacing a pitman stick on a John Deere 8w #1
redsky47
longmont, co
kioti 3054
Took the pitman stick off of my John Deere 8W sickle mower to check for cracks and when I put it back on, I had trouble compressing the spring. Ultimately the spring expanded and broke the spring socket drilled into the end of the wooden pitman (some irony there... ), so I ordered another one. Anyone have any suggestions on the best way to re-install a pitman arm that doesn't involve wrestling, a red face and lots of sweating?
Redsky47
   / replacing a pitman stick on a John Deere 8w #2
Redsky47
The only way I've been able to compress the spring is by using the mechanical advantage built into my jd9. Bolt the flywheel end of the stick on. Clamp the brackets to the stick, I use C-clamps. with the fork and spring installed between them and the spring extended. Loosely place the fork and brackets around the mower knuckle. Clamp the cutter bar in the full retracted position and hand crank the pto shaft until the holes in the shaft line up. Quite often they won't quite lineup and I push phillips screwdrivers through two bolt holes to complete the alignment.
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A52576)
2015 KENWORTH T370...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A52748)
2023 NEW HOLLAND...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
500BBL WHEELED FRAC TANK (A52472)
500BBL WHEELED...
2012 FORD F-250 XL SUPER DUTY (A52472)
2012 FORD F-250 XL...
