Replacement Rims
   / Replacement Rims #1
SRF34
I have a 1320 with calcium filled turf 13.6-16 tires. There is a lot of corrosion in the area around the valve stem. There currently is no signs of any leaking but I cant tell if its just surface corrosion or something deeper/worse. I was tempted to start scraping/poking to see how bad it is but am concerned I might open a problem immediately. So, any thoughts on checking the corrosion? Thoughts on practicing prevention maintenance and replacing the rims now and filling with beet juice/washer fluid? If I do replace the rims, any sources besides the local NH dealer, is that a standard rim size? Thanks for any feedback.
   / Replacement Rims #2
The rims are pretty thick and heavy. It's be a long time before it would rust through and cause a problem. Wire brush it, touch it up, and use it for another 10 years.
   / Replacement Rims #3
The best thing I've found for corrosion is rust reformer by rustolium. It works great. I wouldn't worry about them ruting through to bad though, you could always put a tube in the tire.
2000 Volvo VNL Truck, VIN # 4V4N21JF4YN250174 (A51572)
2000 Volvo VNL...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
