Replacement or alternative mower spindles?
   / Replacement or alternative mower spindles? #1
repair1
Bronze Member
Kubota BX2360, Kubota 726 XKW 60
Hello,
I'm usually lurking in the Kubota or SCUT forums but have a Wheelhorse 312-8 and a C110 with 42" decks that need repiair. My question is, Has anyone found a spindle that is the right hight to replace the Wheelhorse spindles? I'm seriously thinking about fabricating my own but why reinvent the wheel if it already exsits? I purchased the 312 new in 1990 and the 1974 C110 was my Dad's. We used the 312 to mow 2 acres until we bought the Kubota 2 years ago and still use it to trim, pull the trailer and leaf vacuum. I think if the oil is changed and air filter replaced regularly, those little Kohlers will run forevever but the "weak links" (if 20+ years is weak?:) are the origional mower spindles/bearings.
   / Replacement or alternative mower spindles? #2
you can still get spindles.get the model # off of deck & go to a toro site or go to e bay,that's where i get mine.
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A52706)
2019 CATERPILLAR...
2016 KENWORTH T370 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T370...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
Generac S/A Towable Light Tower. (A52377)
Generac S/A...
