Replacement of Ign Switch
   / Replacement of Ign Switch #1
tstex
Platinum Member
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
Hello to all,
I believe my ignition switch is toast on my 96-97 M5400S. I'm picking up a Kubota OEM Switch tomorrow morning and was seeking help from you guys that have performed the install?
Basically looking for the steps to remove and install the switch, then any specific things I need to watch out for or make sure I do or do not do. I would be indebted to your help. We are getting 4-6 inches of rain starting late aftn Friday Dec 2 and I really need to shred around my 3 ponds before the rain gets here, otherwise I have to wait until spring.
Thank you very much for your help,
tstex
   / Replacement of Ign Switch #2
Pretty straight forward replacement. Unscrew the bezel on the outside of the switch and if plug connected just unplug old and install new.
If wired with screwed then unscrew and attach wires to new switch.
Getting the switch in and out of the dash maybe a little more challenging on some models.
   / Replacement of Ign Switch #3
Can't help with your specific model but it should be pretty straight forward and easy to change. First thing to do would be disconnect the battery. Then remove under dash covers (if any) to gain access to the switch. Once the switch is removed its a matter of transferring one wire at a time from the old to the new switch or entire plug if so equipped. Reinstall the switch then connect the battery to test start. If all goes well replace the under dash covers.
Hopefully if there are any other specifics someone else will pop in to explain.
Dave and George - thank you very, very much.
The Op's manual is pretty void of anything. Of the switch, all you see is the Chrome round piece and the ignition slot for the key. I'm going to have to do some digging to get to the back or where the wiring is located. I do not think I will be able to just remove the bezel and start work. Once I get the new part, I'll see exactly what I have to replace. I am also thinking of taking the wrong turn out the dealerships front door and head to the mechanics area. Going to see if those guys can give me a hand..thanks again guys.
Ok, I successfully replaced the ignition switch for the M5400S Series Tractor. If anyone wants to know how, here are the steps:
1. Trace all your wiring lines to make sure nothing is chewed for frayed. None of mine were. Disconnect battery.
2. Unfortunately, you have to remove the gray dash cover, but that won't do you any good until you remove the steering wheel. First thing is you unscrew the bezel of the ign switch. Then remove the six screws around the dash.
3. So, you take a flathead screw diver and pop off the steering wheel cover, there 3 plastic prongs that attach it. You will need a Pulley-Puller tool, which I never heard of and had to borrow one. My tractor is 19-20 yrs old, so you some PB Blaster on the shaft after you take off the steering wheel nut and lock washer.
3. Once the steering wheel is off, you can remove the dash cover and pull the ign switch out and it will hang there [note that when you remove the ign switch, there is a sm notch in the top of the plastic that tells you where the switch goes back. There is also an open hole at the top of the switch too. I vacuumed a lot of crxp out of that area first since I had it open. I removed one wire from the old swtich at a time and put it exactly on the new switch. you use a Phillips head screwdiver to remove the screws, but put some PB Blaster on them too. They seemed to have been welded on there. If fact, one screw got stripped, so I had to use my vice grips to remove it. There are also these runner covers over the screws and the contacts on the swtich...a little PB Blaster just before the back end of the rubber cover on the wire really helped to slide them back, and re-slide them back on the new switch. There's a total of 5 contacts, but you will only use 4 of them. The one you won't use has a cover over it and I transferred it to the new switch too. Make sure you don't wait to do the center one last...little room then. I also did not slide all the rubber covers back on until I had all 4 new contacts re-attached - makes it easier to work. I also took my vice-grips and torqued them just as tight as it took to remove them.
4. Once they are all connected, slide down the covers. I then took electrical tape and completely wrapped all the contacts rom the ign switch all the way down the wiring harness until where is was already wrapped w wire. This will keep moisture, dirt and other out. One done, I properly aligned and reinserted the ignition back into the dash cover, then put on the white washer on the outside, then screwed on the bezel. To make sure it was all done right before I reassembled, I reconnected the battery, got back in seat and inserted the key, turned switch to left and got the red-glow-plug-light on dash, turned her to the right and she started fine as before...then you reassemble/
Finally. before I replaced switch, I was going to replace my fan belt, but the one I had still looked good. Here's a big tip for tightening the current one.
It's stated that you have to loosen both screws that secures the alternator. Make sure you only loosen the top one just enough to break the current torque level. That top screw also holds in water-pump. When I loosed the bottom screw, I then used a crow bar to lightly push down the alternator to tighten her to spec. Well, when I did that, I saw a few drops of antifreeze come out of the water pump seal - the whole county heard my new few words. I was scared I broke the seal/gasket. Once I got the alternator where I wanted it, I re-tightened bottom, then top bolt. I torqued that top bolt a tab tighter than before, and I tighten the one next to it, not a whole lot to throw off the torque pattern btw all the bolts. Once I started her, I open the hood and let her run for about ten minutes to see if it leaked any. By the Grace of God it did not. I then drove my tractor back to where I borrowed the pulley puller [2 miles] and popped the hood there too, no leak. The point is, I was not aware that bolt for the alternator also held together part of the cooling system...I check it again after I really work her hard to make sure no leaks.
Hope this helps. I did not edit this, so.... :)
   / Replacement of Ign Switch #6
Hi everyone...i am a new user here. As per my knowledge you should unscrew the bezel on the outside of the switch and if plug connected just unplug old and install new.If wired with screwed then unscrew and attach wires to new switch.
Under Body Toolbox (A51573)
Under Body Toolbox...
2022 Case IH Magnum 340 AFS MFWD Tractor (A53342)
2022 Case IH...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A53472)
UNVERFERTH 330 -...
2021 JOHN DEERE 8R 370 LOT NUMBER 188 (A53084)
2021 JOHN DEERE 8R...
New/Unused 84in Quick Attach Rock Bucket (A51573)
New/Unused 84in...
