rangerfredbob
Veteran Member
I have an old Kubota L260 with a Kwik Way loader that's undersize for the tractor but works fine... it has an external belt drive pump in the 8gpm range, the ancient loader valve is toast, my right shoe I was wearing while moving some dirt last weekend is NOT gonna rust... I'd rebuild the valve but doubt it's worth it...
Currently the valve is a two stick that's even hooked up backward (right stick is up/down, left is tilt, I'm pretty sure that's not right but whatever...) so I'll fix that and get used to that again later... it's also I think 1/4" NPT on the outputs and 3/8 NPT on the supply/return so staying NPT would be easiest but that's why I'm here... Here's a pic of the current valve a few years ago before the leaks got REALLY bad:
Looking at the budget friendly valves I'm seeing $70-120 all over with a bunch of near identical valves, most of which have BSP threads, some SAE O ring boss but much harder to find... Saw on the Vevor website they have a three spool valve with 3 sticks that's NPT for $75 shipped that is very tempting...
Looking at the pic I guess my hoses are mostly 3/8" NPT with one SAE/JIC for good measure...
So, what would you guys put in there? I'm all for single stick but would rather not invest a fortune in hoses or fittings to convert to SAE O ring or BSP, unless you can just tap out the BSP holes for NPT which I'd be all for... I don't mind getting bushings going from 1/2" NPT to 3/8" NPT... I'm pretty sure the 11gpm options would be reasonable...
