Oil & Fuel Replacement Hydro/Gear oil.
   / Replacement Hydro/Gear oil. #1
M. Lowes
I must change a hydro cylinder out on my L2880 tractor.
Must I use Kubota brand hydro oil, or can I use an other brand oil?
What is the real deal with hydro oil?
   / Replacement Hydro/Gear oil. #2
You can use whatever brand you like as long as it meets Kubota spec.
   / Replacement Hydro/Gear oil. #4
Look at the spec sheet or product container. It should say it meets and or exceeds whatever type of fluid you need, ie. UDT or SUDT.
   / Replacement Hydro/Gear oil. #5
And stuff like "Premium" Tractor Hyd. fluid sold at big name stores only meets Kubotas Super UDT formula spec.s.
   / Replacement Hydro/Gear oil. #6
As a rule, if its gear or shutttle your okay with UDT. If its a hydro pony up for SUDT, its worth the cost difference.
   / Replacement Hydro/Gear oil. #7
Ooops, I meant Premium Tractor juice only meets UDT and not super UDT (SUDT). Sorry.
It is gear shift. I have Universal hydro fluid for the log splitter etc.
I'm just thinking of any difference in weight.
Looking at he kubota web site:
Kubota Tractor USA - Lubricants Schedule
It says use: ISO 32, ISO 46, or ISO 68
ISO 32 or ISO 46 ISO 68 for colder temps
ISO 68 for warmer temps.
   / Replacement Hydro/Gear oil. #9
2014 Ford Taurus Sedan (A50324)
2014 Ford Taurus...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2005 INTERNATIONAL 4300 CARGO TRUCK (INOPERABLE) (A50854)
2005 INTERNATIONAL...
