Replacement Hydraulic Connector Covers -- easy solution???
   / Replacement Hydraulic Connector Covers -- easy solution??? #1
Mike_S
South of Kansas City
JD4400HST
Every 3-4 years the hydraulic connector covers/plugs for the FEL on my 4400HST must be replaced because they harden up and become impossible to use. The female side of the four couplers is a royal PITA to take loose from the bracket in order to slide the tail loops of the POS JD OEM hydraulic connector covers on and then remount the four couplers into the bracket.
This time I would love to avoid going through that nightmare -- are there any hydraulic connector covers/plugs that fit my tractor which have tails that "snap on" the hydraulic lines so that the female connectors do NOT have to be removed from the bracket that holds them -- OR is there another solution??
Thanks (kindly forgive crossposting to the hydraulic forum since this is not a JD-only scenario)
Mike_S
   / Replacement Hydraulic Connector Covers -- easy solution??? #2
Replied in Hydraulics
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
GENERATOR (A53843)
GENERATOR (A53843)
2018 TY-CROP MANUFACTURING LTD DRY BULK PNEUMATIC TRAILER (A53843)
2018 TY-CROP...
CAT 973 (A47384)
CAT 973 (A47384)
MISC PIPE WRENCHES (A53843)
MISC PIPE WRENCHES...
30007 (A53424)
30007 (A53424)
