Replacement Headlight Bulb, 3510
   / Replacement Headlight Bulb, 3510 #1
stevewm
The right front headlight is out on my 2005 3510 tractor. The illustrated parts breakdown that came with my tractor shows a headlight assembly but no replaceable bulb. I did a slightly more than cursory look at the headlight and it looks like the bulb socket is an integral part of the reflector and can't be removed. The headlight itself is held in by three nuts on bolts that protrude from the headlight mount on the grill. Checked the online parts breakdown when it was up and it showed two assemblies, an older and newer style. The newer style showed a separate replaceable bulb. I ordered a replacement headlight assembly from Big Red's and received a bulb instead. The parts girl seems confused; the current parts lookup they have online shows what looks like the newer style with the replaceable bulb. Has anyone else run into this and found a solution? Or am I just looking at the headlight assembly wrong and I can replace just the bulb on the older style.
Steve in Central TX.
   / Replacement Headlight Bulb, 3510 #2
I have a 2007 2910 just changed one of mind take the clip out bulb will come out got the bulb from auto zone H-4 bulb.
hope this helps.
2019 Chevrolet Equinox SUV (A51694)
2019 Chevrolet...
2020 Terex RL4 Towable Light Tower (A51691)
2020 Terex RL4...
2025 Forklift Safety Man Basket (A51691)
2025 Forklift...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2017 JEEP CHEROKEE (A53843)
2017 JEEP CHEROKEE...
