Buying Advice Replacement Glass Door for 3510 Cab
   / Replacement Glass Door for 3510 Cab #1
KenGod
PA
CK2610HST
I broke my left door on a tree. My Kioti dealer wants $600 for the left door glass. Is there any after market places that I can purchase for less?
$600 seems excessive for one door glass.
My cab model #CKA132
   / Replacement Glass Door for 3510 Cab #2
Plexiglass cut on a band saw? Call a commercial glass installer and ask whats available from their insulated glass supplier.
   / Replacement Glass Door for 3510 Cab #3
Check with a local glass company to see if they can supply or cut a safety glass replacement. I have read they can do it for flat panels.
If you substitute any type plastic you want to use polycarbonate (Lexan). NOT acrylic (Plexiglass).
   / Replacement Glass Door for 3510 Cab #4
If the doors are anything like those on my CK4220, they are quite a specific design, with curved glass, holes for hinges and handles, and dust proof seals. Personally, I'd want the OEM item.
   / Replacement Glass Door for 3510 Cab #5
A new truck windshield is almost as expensive. Curved glass is not cheap
   / Replacement Glass Door for 3510 Cab #7
Good to know that Kioti glass is reasonably priced. I would have expected a lot more.
   / Replacement Glass Door for 3510 Cab #8
Glass at retail is not glass at wholesale-this definitely includes vehicle windshields, plus it also comes in grades.
Flat safety glass is a fact. If flat, buy the plastic as a rectangle then bandsaw it out.
   / Replacement Glass Door for 3510 Cab #9
Actually @ $600 that is well in line with automotive glass prices and perhaps even on low side.
Big difference is due to lesser volume there are no aftermarket vendors.
   / Replacement Glass Door for 3510 Cab #10
Been there, done that!
Shell out for the proper door. That helps remind you to NOT do what you did to break the first one! I spent HOURS picking out glass from my woods after breaking my door; it was like staying behind in school to write "I will not..." a hundred times on the chalkboard!
TIP: ALWAYS close cab doors; no exceptions (otherwise you'll make excuses that will get you right back into this situation)
I had about 700 hrs on my NX when I blew out my left door. Considering the environment I have, all those predicting it to be idiocy to operate cabbed tractors in woods, I feel that it's really no more than normal wear and tear: of course, I'd have to go another 700 hrs to make this work out.
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
Unused 2025 CFG XZ20R Mini Excavator (A49461)
Unused 2025 CFG...
Payment Terms (MUST READ) (A50774)
Payment Terms...
2004 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2004 V.E...
71053 (A49346)
71053 (A49346)
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
