Replacement for White 2-70??
   / Replacement for White 2-70?? #1
Harold_J
Would one of the M-series be an adequate replacement for a White 2-70 (Oliver 1655) diesel that I currently own? I would be using it on 25 acres to grow vegetables using implements such as 150 gallon 3 point sprayer, 10' 3-point disc, 3x16" 3-pt plow and a 2x16" rollover plow. I might want to move up to a 3x16" rollover plow if possible.
It seems like the M-series have the horsepower but not the weight of the older farm tractors, almost like comparing a manufacturer's compact utility tractor to a regular utility of the same horsepower. I am sure the White weighs over 7000 lbs; the engine is 283 cu. inches, around 72 hp.
What, if anything, would be a Kubota equivalent model?
2015 Ford Transit 150 Cargo Van (A55788)
2015 Ford Transit...
40006 (A53422)
40006 (A53422)
2012 Freightliner M2 112 Fuel and Lube Truck, VIN # 1FUGC5DV5CHBF7397 (A54865)
2012 Freightliner...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52705)
2017 CASE IH 580...
2023 CATERPILLAR 299D3 XE SKID STEER (A52705)
2023 CATERPILLAR...
