enginesludge
First off, I like to say thank you again for the excellent help I got regarding the hydrostatic transmission. I posted somewhere on tractorbynet. Not Kubota forum, I did not see that. It turned out I was still running factory fluid and filter. I kinda forgot, think I am 1000 or 1200 hrs now on my BX2200. Replaced both and got more than enough getup and go for my needs. Now that I am running strong, I have what I assume is just an annoying problem.
After sitting, I see a messy puddle of gear oil under the left front wheel/hinge point. Not a lot but messy in a garage. I read somewhere that this is typical for an old machine. Also I recall some one suggested a heavier oil for a quick fix? But that old thread seem to suggest a multi viscosity where I would have expect straight 90wt or something?
I never run this tractor in winter. Only engage 4wd briefly when I get stuck. Is there a potential for an easy/sleezy fluid fix here? What can I get away with?
