Replacement engine
   / Replacement engine #1
Elmaguy
I own a 2004 Cub Cadet LT1018. It has a Briggs and Stratton 31Q777-0305 18.5 HP engine in it. Last week, it died. The last time I rode it, I thought it was running out of gas. When I shut it down, it let out a puff of smoke. I noticed that the engine was extraordinarily hot as well. Now, when I try to start it, it sounds almost like a diesel engine. I was told the piston rod most likely broke due to overheating. The shop I purchased it from wants $1500 + labor to relace the engine OR I could buy a used engine from another tractor the mechanic owns and he'd put it in for me.
Which leads me to my question...
Can I just buy a similarly powered vertical-shafted engine and put it in myself? I see engines for around $500:
Kohler SV600S-0003 20 HP
Small Engine Surplus.com 445577-0435 Briggs & Stratton 23 hp
Is this feasible? Any advice?
   / Replacement engine #3
If you can mount an engine so that the shaft lines up correctly, you can use the engine. I would be careful, though, about putting too big (or too small) an engine in. You wouldn't want to be over-powered any more than than under-powered, lest you start breaking other parts a little too easily.
   / Replacement engine #4
It isn't a hard job. I replaced several engines on mowers. Make sure the engine shaft length allows you to line up the pullys.
2000 Sterling L9513 Winch Truck (A53473)
2000 Sterling...
LINDE H70 FORKLIFT (A53843)
LINDE H70 FORKLIFT...
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
2010 Chevrolet Tahoe SUV (A53424)
2010 Chevrolet...
2015 New Holland Boomer 47 4WD Agricultural Utility Tractor (A53421)
2015 New Holland...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
