Replacement Clutch Specs
   / Replacement Clutch Specs #1
Logan11350
John Deere 5400
Hello All,
I am new hear but I am working on my John Deere 5400. I installed a Reman Complete Clutch from John Deere. My main concern is that when I put the tractor together the clutch pedal was very loose and I had to pull out all of the adjustment to get it back into clutch play spec. I am able to achieve this but again the pedal adjustment is pulled completely in to do so. I was told by Tri-Green that the clutch fingers should already be adjusted to spec. Is this correct? Do the clutches typically come pre-adjusted? I have only snugged the clutch housing bolts so at this point it would be quick and easy to separate and check. Unfortunately I missed the clutch finger adjustment tool specs in the back of the manual until I got to this point as I thought it was pre-adjusted. Any help or advice from past experience would be much appreciated. Also the PTO shaft spun freely before re-attaching the halves but now that its together it will not spin. Everything lined up correctly, I wiggled the PTO shaft and that went in and then wiggled the craftshaft until that slid in. I have the 9 speed Synchronized for reference.
Thanks,
Logan
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2015 SKY TRAK 6036 TELEHANDLER (A56129)
2015 SKY TRAK 6036...
kids dirt bike (A56859)
kids dirt bike...
2018 Bandit 15XP Wood Chipper (A57453)
2018 Bandit 15XP...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
