replacement battery for TYM T233?
   / replacement battery for TYM T233? #1
pcaskey
Austin, Texas
TYM T233, Ford 8N
Anyone know of a good battery to replace the OEM battery (AtlasBX 40R) on a 2006 T233?
Dealer (and other posts) says a battery group size of 51 will do it, but it won't fit (my tractor has the FEL, but otherwise has not been modified). The battery box has a max of ~8 inches in length (distance between terminals) between the support rods that hold the battery hold-down bracket and the group size 51 batteries are all ~10 inches long (otherwise height and depth are OK).
The only other size battery that I can see would likely fit is a U1 (lawn/garden), but trying to find a U1 size battery with the required 38 AH of capacity (from owner's manual) is proving difficult.
Thanks for any help,
   / replacement battery for TYM T233? #2
I used the 51 and bungeed it down.if u make it fall out,ur in trouble! LOL
   / replacement battery for TYM T233? #3
This is what I had in mine. YUSASA 40B19L(s) identical in size to the original but had full size terminals not the tiny ones like the original. My local farm store got it from the Interstate battery dealer.
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
HURRICANE 40' CONTAINER (A51248)
HURRICANE 40'...
JOHN DEERE CP690 LOT IDENTIFIER 70 (A53084)
JOHN DEERE CP690...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53472)
2019 New Holland...
