replaced all coolant hoses...need to bleed?
   / replaced all coolant hoses...need to bleed? #1
mattbatson
canton, nc
kubota B1750HST4x4
Before I fired up the ole b1750 I wanted to be safe and come on here and ask first...
I pulled the radiator so I could get back to the little coolant hoses that are hidden behind the fan and belt. They all looked original and very old...
so, everything is bolted back up and 50/50 coolant is poured into the radiator.
Do I need to do any kind of bleeding or burping, or can I just fire it up?
With my gas car's I wouldn't do anything special after replacing radiators/hoses, and would just fire it up.
But, this is a diesel tractor, and I'm still learning.
thx
   / replaced all coolant hoses...need to bleed? #2
I would start it up and let it warm a bit and then check the fluid level. You'll find you will need to add a bit as the air is driven out of the block and heater (if you have one).
   / replaced all coolant hoses...need to bleed? #3
It should be fine. Most systems are self bleeding but usually you need to warm it up to the point where the thermostat will open to get rid of all the air.
Of course if it is the old siphon system then there is no thermostat and you should be good to go.
thanks for the replies...
I will just start it up and treat it like my auto's...be sure to check level after warm
appreciate it
Volvo A30D - Arctic Truck (A42203)
Volvo A30D -...
PTO Driven Winch (A44391)
PTO Driven Winch...
2024 EGN EG360T Ride-On Skid Steer (A42203)
2024 EGN EG360T...
USA 30" 5T Excavator Bucket (A42203)
USA 30" 5T...
2014 WESTERN STAR  4900 SF (INOPERABLE) (A45333)
2014 WESTERN STAR...
SWEETWATER METAL PRODUCTS LINE TAMER TRAILER (A45333)
SWEETWATER METAL...
