Replaced a box trailer vent cap
   / Replaced a box trailer vent cap #1
nikdfish
Veteran Member
Person Co. NC
John Deere 3038E & 1025R FILB
I've been doing some updates on our little 6x12 single axle box trailer (fender running lights replaced with LEDs & new tires), and finally got around to addressing the vent cap. The cap on the pop-up vent had degraded over time (12+ years?) and been taped over multiple times. Initially the tape was to cover a crack, eventually it was the only thing holding things together. I had worried I might need to replace the whole vent assembly but, after looking at options, found I could replace just the cap itself from a third party source.
The replacement cap I got is made by Camco. Their website has a good series of illustrations to help identify what model cap you need for your given trailer vent (there are quite a few variations of hinge for 14"x14" vents). After identifying the style hinge needed, I went with the "unbreakable" polycarbonate version cap & ordered through Amazon for about $24, delivered.
The pics are post-removal of the old cap, but the steps involved are all there.
The old & new cap after initial placement.
This style of hinge has a kind of "P" shaped channel on base & "U" shaped on on the cap, one nesting in the other. Tabs are bent in at the ends keep things lined up. With everything else removed, unbend a tab on the old cap & slide it off. Bend one tab on the new one & slide it on.
Close the cap on the opening & go inside
Insert the crank mechanism arm in the cap slot and secure the mechanism with two screws.
The screen goes back on, secured with two screws.
With the screen on, put the crank arm back on & secure with one screw.
The trim ring goes on, secured with four screws.
The last step is going up on the opposite side of the trailer to bend the other end tab to keep the cap secure.
The old cap material was pretty thin & got brittle over time.
It was definitely past time to get this done & turned out to be much simpler that I had originally worried it was going to be.
Nick
   / Replaced a box trailer vent cap #2
Thanks for the heads up about Camco. I've got one that's been held together with Gorilla tape the last couple years. I've replaced the entire units on other trailers a couple of times in the past. That sealant they used around the flange is some tough stuff.
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2019 Kenworth T270 Truck, VIN # 2NKHHM6X3KM358768 (A51572)
2019 Kenworth T270...
HYDRAULIC SKID (A52472)
HYDRAULIC SKID...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
