replace single action plow angle cylinders with d/a type
   / replace single action plow angle cylinders with d/a type #1
roman
W Central New Hampshire
MF 30(sold) Ford 1520(sold) Ford 1720(sold) Kioti CK4010SE HST Cab
I have aford 1720 with fischer 7' that replaces the bucket. I tried to angle the plow with curl function but need d/a cylinders. I dont need power beyond loop and think the d/a cylinders are a cheaper route with the same end result.
What do I need to think about other than matching the cylinders? Any tips??
Thanks, Roman
   / replace single action plow angle cylinders with d/a type #2
You are throwing money around without addressing the problem. Two single acting cylinders will angle a snowplow just as well as double acting cylinders, or just as poorly with improper valving. You need a non-regenerative valve spool in your curl circuit, or a different valve. Much discussion here if you search for it.
   / replace single action plow angle cylinders with d/a type #3
Like Rick wrote, do a search of the term "regen" for lots of reading. I think some of the older Fords used a style of valve that had regen full time whereas the newer tractors (all brands) there is a lockout for it.
Thanks guys... I will check into it!
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
1999 CASE 721C WHEEL LOADER (A53843)
1999 CASE 721C...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
CASE 580 (A47477)
CASE 580 (A47477)
2025 IR IRE20 Mini Excavator (A52377)
2025 IR IRE20 Mini...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2021 FREIGHTLINER...
