Replace Seals in 3pt Cylinder
   / Replace Seals in 3pt Cylinder #1
njensen
All,
My friend has a leaky seal in a 3 point hitch on his JM284, (the hitch drifting back into low position slowly tells the tale). I've actually replaced the seals in my 3pt before, (JM184), and it certainly wasn't a bad job. However, at the time I did mine, I remember having a fairly good how to that was posted on line.
I've been searching for a while now, and the best one that I have been able to dig up is at:
Chinese Tractor Owners Association - CTOA Forums - Do it yourself projects to share - Jinma 25hp 2425 / 254 3pt LIFT BOX REPAIR HOW-TO
I don't think this is the one that I followed, (but perhaps it will suffice). However, if anyone has a link to a good howto on the procedure I would really appreciate it.
Thanks,
Nate
Greg,
As always, your info is quite helpful. We knocked that 3pt out in about an hour! Holds implements up indefinitely now.
-Nate
TROY BILT PRESSURE WASHER (A51248)
TROY BILT PRESSURE...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 78"...
(5) 55 GALLON POLY DRUMS (A51248)
(5) 55 GALLON POLY...
UNUSED CFG INDUSTRIAL QK18R EXCAVATOR (A51247)
UNUSED CFG...
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
