Replace priming pump with priming bulb? or? (John Deere)
   / Replace priming pump with priming bulb? or? (John Deere) #1
battalioncheef
Hutto
John Deere 5105
I have a John Deere 5105 and believe I am having trouble bleeding the fuel system.
Here is a link to a picture of the seal from inside the hand priming pump located near the engine.
216-4-16_13-16-48.png - PowerWithAmbit's library
It looks to me that 'deformed' area of the seal is keeping it from acting as a 'one way' valve when the hand plunger is pushed.
So, THAT seal is about $80. I could spend that,,.. but gosh, $80 for a 1 1/4" rubber seal... man..
QUESTION, Do you think an inline bulb fuel primer would work? Those are available for $20 (for diesel use)...
I am not a veteran diesel guy - so, this could be a dumb question.. Go easy..
For clarification: I would leave the existing pump in place, as it houses a filter, and I would place the bulb primer just 'upstream' of this pump, which actually just becomes the filter housing/mount with the 'pump' aspect 'disabled.'
2015 Top Hat T/A 20 ft. Gooseneck Trailer (A53117)
2015 Top Hat T/A...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
PNEUMATIC GREASE UNIT (A53843)
PNEUMATIC GREASE...
INDUSTRIAL UNISAW TABLE SAW (A51248)
INDUSTRIAL UNISAW...
UNUSED FUTURE SF60 HYD MAST W/ 60" FORKS (A51248)
UNUSED FUTURE SF60...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
