Replace mid-PTO seal on B7610
   / Replace mid-PTO seal on B7610 #1
Joe 7610
My Kubota B7610 is leaking oil at the mid-PTO, and I want to replace the seal. Does anyone know where I can get directions? I have the service manual, but it doesn't cover this.
   / Replace mid-PTO seal on B7610 #2
pry the old eal out with something (usually it ends up being the best screw driver you have because the old one's you dont care about just dont seem to fit as well, but thats life)you will damage it, dont worry, you have a new one.
its about now you realize you should have drained all the trans oil into a clean tub as opposed to on the floor like it now is. clean around the outer of the seal bore, put some sealant onto the outer of the seal and tap the new seal in gently with a hammer, making sure it goes in square and you dont dint it.
   / Replace mid-PTO seal on B7610 #3
pry the old seal out with something (usually it ends up being the best screw driver you have because the old one's you don't care about just don't seem to fit as well, but thats life)you will damage it, don't worry, you have a new one.
its about now you realize you should have drained all the trans oil into a clean tub as opposed to on the floor like it now is. clean around the outer of the seal bore, put some sealant onto the outer of the seal and tap the new seal in gently with a hammer, making sure it goes in square and you don't dint it.
thanks, OT. I appreciate the instructions.
New/Unused 20ft Farm Iron Gate (A48837)
New/Unused 20ft...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50774)
STOP!!!! PLEASE...
Blue Concrete Test Shed (A49461)
Blue Concrete Test...
2007 Terex RS350 Soil Stabilizer/ Reclaimer (A49346)
2007 Terex RS350...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
