Replace injector pump YM2210D
   / Replace injector pump YM2210D #1
Pird
I need a little advice on installing an injector pump on a YM2210D. My ordered service manuals have not arrived and I would like to go ahead and install the pump without them. Can I just cut off the fuel, replace the pump, bleed the fuel line of air, and go. Seem like there would be a problem with air in the fuel below the bleed point. Any special things to look out for or do? Thanks.
   / Replace injector pump YM2210D #2
You will have to remove the fuel pump box cover, 6 screws ( not all the same length ) then reach inside with a crooked needle nose and remove the snap pin from the govenor link, be sure not to drop the snap pin or the little spacer, then the pump will have to be turned a little so the rack will come through the knotch in the side of the block.
Danny
Parker Equipment Co
Thanks Danny. Everything was just as you said and it was pretty straightforward...however some skinny long fingers would have helped. Appreciate it..John /forums/images/graemlins/wink.gif
WOODS DS8.50 LOT IDENTIFIER 232 (A53084)
WOODS DS8.50 LOT...
UNUSED FUTURE 20' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 20'...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51247)
UNUSED FUTURE BOX...
LMC G500-500A LOT IDENTIFIER 217 (A53084)
LMC G500-500A LOT...
