Oil & Fuel Replace fuel shut down cable 1925 NH
   / Replace fuel shut down cable 1925 NH #1
LOOPHOLE
Horry County,SC
140 Farmall w/belly mower NH 1925 FEL/BH
Anyone ever replace fuel shut down cable on a 1925 NH ? Do you take panels off side that has key switch ? Or do you go thru panel at fuse holder ? Advise is WELCOME !
   / Replace fuel shut down cable 1925 NH #2
I don't have a '25.. but am wondering.. can you not just follow your old cable to see how it is run?
Also.. does the 25 not have the same 'key off' system as the 20 series did? If so.. are you talking about the wire to the fuel shutoff solenoid instead? ( there is a good pictoral on changing that solenoid posted by jinman here inthe forum ).
post back with your details..
Soundguy
No shut down soleniod, cable pull acts as choke/to starve fuel. Pull knob fastens to panel w/lock nut on opposite side to hold in place. I was wondering what panels have to come off to gain access to rear of panel. Pull knob is located below start switch aprx 6-8".
   / Replace fuel shut down cable 1925 NH #4
I'm really surprised the 1925 has the pull-to-kill system. My old 5000 has that...
Soundguy
   / Replace fuel shut down cable 1925 NH #5
I stopped by the local dealer while in town today and looked over a couple 25 series machines he had. Wow.. still can't figure out why they had pull-2-kill pumps.. In any case.. they look pretty straight forward to get at behind the front cowling just past the dash. I doub't you will have a problem R&R ing it if you can turn a wrench..
Soundguy
Thanks, I have to take panels off below dash/ should be fun , started repair last nite and found bolts holding panels together below steering wheel are stripped ! The fun begins.
   / Replace fuel shut down cable 1925 NH #7
On al older tractor I found similar stripped nuts holding cowling together, and cowling to dash. I ended up having to split the nuts with a hacksaw blade to get them buggers out.
Good luck.. post back on your progress ( or lack therof ).
Soundguy
   / Replace fuel shut down cable 1925 NH #8
I have a 1725 and it is similar, you have to break apart the two cowl pieces, they are bolted together in the middle, then you loosen the cable at the engine and then the nut from the pull knob. Kind of a pain, these things tend to get stickey and then you have to replace them. cables aren't too expensive but unbolting everything to get them out is kind of a pain.
   / Replace fuel shut down cable 1925 NH #9
My 1925 I drilled through that center cowl and it (the center cowl) is held on with nuts and bolts now.
I found bolts holding cowl together stripped,so I took bolts out from firewall and took cowl off in one piece.Decided to drill bolts out in case switch or cable goes haywire later,put back together with bolt and lock nut.Overall not a bad job, you just have to perform an autopsy on tractor to get to.Noticed after getting cable in place you had to pull knob out about 3" to shut fuel off.So I pulled lever down on fuel pump to shorten distance on pull knob.Shuts down pulling knob about 1". Found it a good time to adjust friction plate on throttle control. Many thanks for advise !
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2010 Honda CR-V SUV (A51694)
2010 Honda CR-V...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
LMC LOT NUMBER 144 (A53084)
LMC LOT NUMBER 144...
5ft Rotary Cutter (A51573)
5ft Rotary Cutter...
