Replace fuel injectors in Ford 3930
   / Replace fuel injectors in Ford 3930 #1
jlanglois
Ford 3930
Having watched a wonderful video on replacing the fuel injectors on a Ford tractor, see
, I decided that would be my next project.
Imagine my surprise when I went to swing out the battery box and realized the front-end-loader was in the way.
If I take the battery out can I get to the injectors or is there some secret procedure I need to pursue?
Thanks.
   / Replace fuel injectors in Ford 3930 #2
1 - If you take the box/tray out you should have room
OR
2 - Raise the loader and prop it in the raised position with 2 stout (1.5 - 2") angle iron supports laid on the cylinder rods and secured with hose clamps.
Thank you tractor tech.
Even with the FEL fully raised there is not enough clearance to swing the battery tray out because of the side braces.
Looks like taking the battery out is my only option.
Well, this has turned into an adventure. I was able to remove the battery and tray without removing the front-end-loader.
Imagine my surprise when the fuel injectors I ordered did not fit the tractor. The cover on the tip was a different size.
When I called the parts people they asked me to provide the original part number from the New Holland parts catalog.
It turns out that part number 87800132 was never released into the after market manufacturing system.
To make matters worse, when I called the local New Holland dealers, they told me they can not get the part either.
So now I am trying to find a way to clean these original injectors. Do I just soak them or do I need to take them apart?
Thanks.
   / Replace fuel injectors in Ford 3930 #5
Thanks.
Why don't you just leave them be and run some fuel injector cleaner? You can get them tested if it doesn't run at all.
   / Replace fuel injectors in Ford 3930 #7
Emissionzed engine. Figures
Thank you for the offer thempumpguysc. I ran some SeaFoam through it and it seems to have helped considerably.
   / Replace fuel injectors in Ford 3930 #10
I reviewed this thread and seem to have the similar issue on my New Holland 3930. Tractor starts but has the funny "dry" clacky sound that gets worse as it runs and has a small bit of white smoke. Few options in my area for repair and one truck diesel mechanic an hour away says is sounds like needs injector issue and could haul it to him. I am comfortable with gas tractors yet this is my first diesel tractor. Is injector removal as simple as the video above as the older Fords? And sending the injectors to an injector shop the most straight forward? Any help would be greatly appreciated as I sorely need to brush hog. Thank you,
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A51039)
2018 Rock Solid...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
2020 KUBOTA RTV...
