Replace blades w/chains on rotary mower?
   / Replace blades w/chains on rotary mower? #1
Doug990
Barron co. Wi. USA
JD990
I have lots of rocks on our 80 and have broken several blades on heavy rotary brush mowers. Does antone know if chains would work instead of blades? Thanks, Doug
   / Replace blades w/chains on rotary mower? #2
I don't have any solid reason to feel this way, but I'd be a bit uncomfortable with chains flying around under there, thinking that a few links would be propelled out from under the mower at high speed.
Just thinking that a blade might not be as likely to 'come' loose when being held with 3/4" bolts vs a chain that may have only 3/8" steel in its links.
Notwithstanding that the chain wouldn't be very 'sharp' but would still wear and at some point need to be removed (or remove itself).
But, my mind isn't made up that it won't work. /forums/images/graemlins/wink.gif
   / Replace blades w/chains on rotary mower? #3
Ive seen a few conversions like this one differnt brush cutters. I know ive seen some in Farmshow and also seen a few on RFD tv's Prarie Farm Report Inventions. chains were used on a side shifted trimmer for mowing near metal structures and around rocks. It worked pretty good. I recorded the episode if i run across it on tape i can get their number.
   / Replace blades w/chains on rotary mower? #4
I know a guy who has "80 acres of rocks". He replaced the swinging blades with ones made from used road grader bits. Stay sharp, durable, and pretty indesructable.
   / Replace blades w/chains on rotary mower? #5
My brothers auto truck spring shop would have farmers to ask for lengths of used spring leaves. They would drill holes in one end and sharpen one edge for their bush hog mowers. They said they lasted a long time.
   / Replace blades w/chains on rotary mower? #6
Are you familiar with a flail type mower? It uses a row of chains that run vertically and is designed to safely run through rocks etc.
   / Replace blades w/chains on rotary mower? #7
I second the flail ... I picked one up this season cus I got tired of buying spindles on my finish mower (lots of exposed ledge on my property) .... It cuts great ... I can mow areas I could never think of with the finish or rotary mower ... Scozz
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2012 RAM 5500 (A52472)
1991 HEIL FUEL TRANSPORT TRAILER (A52472)
1991 HEIL FUEL...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A52748)
GOODYEAR SET OF...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
