Repairing cast suspension knuckle.
   / Repairing cast suspension knuckle. #1
tcartwri
Veteran Member
Ontario
CT235
Broke a rear suspension knuckle from my Explorer pressing out a bearing.... :thumbsup: One of the ears that the the lower control arm bolts through has a crack in it. No idea if this is cast iron or an alloy. Should I even think about getting it welded?
It's a holiday of course, so I couldn't price out a replacement. I think the dealer will be looking for $300 or so.
   / Repairing cast suspension knuckle. #3
If it was me, I'd worry about the weld quality and I'd try a "you pull it" type salvage yard. A good used one would surely would be less than $30-40 at a place like that.
You-pull-its and salvage yards are almost a thing of the past around here.
   / Repairing cast suspension knuckle. #5
Yep, the local one I go to won't let you into the yard without an employee with you. Insurance requirement.
Ian
   / Repairing cast suspension knuckle. #6
No welding there. Bad idea (very). Search junkyards for parts. A quick internet search should help you find some in your area. They are not gone, just a lot fewer will let you pull parts anymore. There still is at least one in the Mpls/St Paul area that does that.
If you can wait, there are some online sources that are new OEM dealers that sell online at great prices. www.partsguyed.com is a great one, but it comes from the west coast so shipping can be pokey.
   / Repairing cast suspension knuckle. #7
Ebay has some for $105 to $160. Be sure to get the correct side..
4 Yard Commercial Dumpster (A49346)
4 Yard Commercial...
UNUSED KJ 20' X 12' LIVESTOCK METAL SHED (A50460)
UNUSED KJ 20' X...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A48081)
2001 Sterling...
1980 Carley Dump Trailer (A48836)
1980 Carley Dump...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A50397)
NEW 2025 Load...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A50397)
80in HD Tooth...
