Repairing a Bostitch Coil Roofing Nailer
   / Repairing a Bostitch Coil Roofing Nailer #1
Dozernut
Veteran Member
South Eastern Illinois
ZD1211, RTV900, LX2610SU and a SVL65 CTL
I lent my Bostitch roofing nailer to my son-in-law and it came back not working. The nailer keeps jamming in the nose and deforms the nail. I have not tore into yet as I am unsure of exactly how to proceed on the repairs. Any advice or helpful hints would be appreciated. Thanks!
   / Repairing a Bostitch Coil Roofing Nailer #2
My dad's stanley bostitch did the same thing and we ended up ordering a kit for it that had a bunch of O-rings and some other pieces. I think we had to order it from Granger. That has been a few years ago. After putting it back together, it worked like a champ.
   / Repairing a Bostitch Coil Roofing Nailer #3
The coil roofers commonly get gummed up with tar build-up. Some of the better pro lumber yards will stock a cleaner to degrease the gun without damaging o-rings. You can try brake cleaner but, no guaranty it won't harm the o-rings. There is usually a plastic cover over the feeder pawl, remove that and clean. Tar in that area can cause what you're experiencing. Otherwise, you'll be buying an o-ring repair kit.
Update:
Cleaned the nailer up and removed a small piece of nail lodged in the plunger and it is shooting nails like it should. Thanks to both for your replies especially shvl73, that info was just what I needed to get the nailer going again.
   / Repairing a Bostitch Coil Roofing Nailer #5
On my roofing nailer, I routinely spray liberally with WD-40 as it releases all the accumulated tars as well as lubes the gun.
Works for me!
In fact I routinely treat all my nailers with WD-40 and find they really like it.
My Hitachi framing nailer is close to 15 years old and was bought used and never seen a repair to date.
And that gun has 'shot' pallet loads of 3 1/4" nails!
10'x20' Single Garage Metal Shed (A44502)
10'x20' Single...
2019 VALTEK 2500HP FRAC PUMP (A45333)
2019 VALTEK 2500HP...
Hand Sanitizer Stands (A42745)
Hand Sanitizer...
1998 KBH Fertilizer Tender Auger Trailer -30 FT (A44789)
1998 KBH...
Skate Park Assembly (A42745)
Skate Park...
ALLMAND LIGHT TOWER (A45046)
ALLMAND LIGHT...
