Repair Manual Needed !! - JD 410B Backhoe
   / Repair Manual Needed !! - JD 410B Backhoe #1
Greasemonky
Mineral Wells, Texas
John Deere Backhoe model 410B
Anyone by any chance have a repair manual for a JD 410B backhoe they wanna sell ? Or maybe share a little info from it. Mine has no forward . Think the forward clutch pack is out. Wondering the easiest way to get to "reverser" clutches. Not sure if it needs to be split or if it drops out with trans and rear drive ????????
   / Repair Manual Needed !! - JD 410B Backhoe #2
I have a 310 b , its similar . I got it from a friends estate , I am going on memory about 15 years ago he had a similar problem and if my memory is right , you will have to split it . But I will be over my shop the next day or two and I will look for the books , I may have the manual .
Thanks Sprinklerman. I would greatly appreciate it..... I kinda thought it would have to be split by the looks of it. 😝..... But it's gotta be done. Nothin to it but to do it !
   / Repair Manual Needed !! - JD 410B Backhoe #4
Look closely at the shift linkage on RH side as theyy have a history of the pins breaking. I agree tractor has to be split to access reverser. I recommend checking hyd pressures before splitting.
2020 Deere 325G (A50123)
2020 Deere 325G...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53473)
GALAXY - SET OF...
2015 FORD F250 EXT CAB SUPER DUTY (A53843)
2015 FORD F250 EXT...
2013 FRAC TANK (A53843)
2013 FRAC TANK...
1999 TRAILMOBILE DRYVAN (A53843)
1999 TRAILMOBILE...
