Repair fiberglass cab top
   / Repair fiberglass cab top #1
o2batsea
Platinum Member
Maryland
Kioti DK45C 2005
I spent some quality time repairing a serious crack that i created when a partial wall fell on the tractor about a year or so ago ( long story ). I first had to get the cab top off and down where I could work on it. The cab is held in place with 4 12 mm bolts. Once undone ( the frigging lights are so in the way) the top has to be lifted slightly so as to unplug the wires for the lamps. With these loose the top lifts off. It isn't heavy, just darn cumbersome especially when standing in the loader arms. I managed to get it down without killing myself. On the sawbucks, the first thing to do was strip the hardware. Next I ground out the cracks from the inside with an angle grinder fitted with a 50 grit sanding disk. I feathered the cracks back about two inches each side. Next was an acetone wipe down to get any oil, wax or contaminates cleaned up. I cut glass cloth in two and four inch strips. I mixed West System epoxy and painted the entire area with resin. This helps to wet the cloth when laid across the cracks. I use a throwaway paint brush and work the resin into the cloth. I did about six layers. It took about three hours to set. I flipped the top over and ground out the cracks in order to get rid of the ragged edges so I could fill with bondo. Once filled and sanded I finished with orange Hard Nose paint from POR 15. Installation was a reverse of removal. Fun!
   / Repair fiberglass cab top #2
I guess it's just as well it was the tractor and not your head the wall fell on.
Good to know it can be done. I bet this is the last time you will need to do it.
Jon
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
JOHN DEERE 7300 LOT IDENTIFIER 18 (A53084)
JOHN DEERE 7300...
1263 (A50490)
1263 (A50490)
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
