Renting Implements and Hydraulic fliud
   / Renting Implements and Hydraulic fliud #1
CowwFace
Conifer, Colorado
Kioti DK45SE HST, 401FEL, RB40-96 pivoting Rear Blade
Hey List,
I think I might be officially type-A about my tractor now ... the thought of renting implements popped into my mind, and then immediately afterwards I thought about running someone else's nasty hydraulic fluid into my tractor .... Have I gone off of the deep end worrying about this, or has anyone out there had trouble with their pumps after renting equipment?
Tractor on
   / Renting Implements and Hydraulic fliud #2
Do not run any-ones else's hydrualics,buy your own cylinder(s) and use them.
Only asking for trouble.I had not given this a thought until my brother-in-law(a retired farmer) told me this.I buy my own implements as a rule.
   / Renting Implements and Hydraulic fliud #3
I haven't had any trouble, but don't intend to so I don't do it.
   / Renting Implements and Hydraulic fliud #4
I have never seen SCUT/CUT/UT implements for rent. I'm in the greater Sacramento area, which should be a good market for that. But I have never seen anyplace rent.
I have rented breakers, trenchers and clamshell buckets and used them on my buddies Bobcat Skidsteer. Rented some from the Bobcat shop in Sacramento, and some from other local rental places. We just plugged and played; no purging the existing fluid or anything. That, is pretty common.
FWIW, I did get a used 3pt logsplitter for my tractor. I purged the fluid from it before connecting to my nice clean hydro system.
   / Renting Implements and Hydraulic fliud #5
+1 Good idea, that's what I did when borrowing a friend's chipper. The fluid I drained out of the chipper was terrible.
   / Renting Implements and Hydraulic fliud #6
Since my tractor is entirely hydraulic from one common hydraulic tank, I would never use hydraulic rental attachments on it for fear of contaminating the drive pump and wheel motors. Just not worth the risk. That, and the fact that no one rents attachments that fit my tractor anyway! :laughing:
I would instead rent it with its own power source. :thumbsup:
   / Renting Implements and Hydraulic fliud #7
i dont think you boys have to worry about other hydro fluid backflushing from rental equipment an damaging your hydro pumps.because i dont reckon the hydro hoses retain any pil asfter you unhook them.
   / Renting Implements and Hydraulic fliud #8
The splitter I got appeared to have about 2 quarts in it. Not a lot considering my tractor uses 9.6 gallons. But glad I flushed it.
2008 DOOSAN G25 GENERATOR (A53843)
2008 DOOSAN G25...
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
1992 MACK RD688S KILL TRUCK (INOPERABLE) (A53843)
1992 MACK RD688S...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
