Renting Gyrotrac for cleaning up land
   / Renting Gyrotrac for cleaning up land #1
brandon07
Bronze Member
I want to rent a skid steer with a "forestry cutter" attachment to clean up some places on my land. Does anyone know a ballpark price for renting one for a weekend? Also I have a place where I had some pines cut off and was wondering if it would mulch up the stumps sticking out of the ground?
Thanks,
Brandon
   / Renting Gyrotrac for cleaning up land #2
When I looked, it was about $500 a day out of bowling Green KY. No idea where you are at though, you may want to fill in some profile info to get better information.
I had to hunt to find one, finally found one at the CAT place.
I'm in Panama City, FL. I haven't seen one, but I haven't looked either. Last time I rented a JD 160 excavator I didn't see one on that lot. Like you said I may have to search around. Thats a lot higher than I thought. ****, I can get a JD 450 dozier for 1200 a week with a root rake.
   / Renting Gyrotrac for cleaning up land #4
The real benefit of using a forestry cutting head is for the mulching capability, so you don't have to deal with burning or hauling off debris. You don't get that capability with a dozer w/ root rake. The mulching head should also take care of grinding up stumps too. You'll just need to get a large enough machine with high flow hyd. to run a good size mulching head. I'd make sure they give you a good set of sharp teeth on the cutter head if you rent one.
2013 John Deere 650K LGP (A47477)
2013 John Deere...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
John Deere 6120E (A50323)
John Deere 6120E...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A53473)
Kubota BX2680...
2016 Clipper Sport 106 17FT S/A Pop Up Camper (A51694)
2016 Clipper Sport...
