Renting a 3pt hitch auger "CENTRAL VA"
   / Renting a 3pt hitch auger "CENTRAL VA" #1
manganos
Platinum Member
Close to Petersburg
Mahindra 2516
Renting a 3pt hitch auger \"CENTRAL VA\"
I'm not having any luck at all finding a 3 pt hitch auger for rent in the area. Does anyone know where I could rent one? Do you have one sitting around and live near Richmond? I'd be willing to rent it from you and pick it up/drop it off. Shoot me an email vamangano*NOSPAM*@yahoo.com . Please remove *NOSPAM* when emailing! Thanks Chris
   / Renting a 3pt hitch auger "CENTRAL VA" #2
Re: Renting a 3pt hitch auger \"CENTRAL VA\"
I used to rent one from Browning Equipment, the Kubota dealer in Purcellville, and I know that they also rent them at Carlyle and Anderson, the JD dealer in Winchester. That's northern Virginia, not near you I know, but have you tried the tractor dealers in the Richmond area? I've not found any "rental places" that rent tractor implements.
   / Renting a 3pt hitch auger "CENTRAL VA" #3
Theros Equipment on the north side of Warrenton is a HUGE rental center. 888-2THEROS
Thanks guys. I will call the local tractor dealers today. Thanks again for the ideas! (warrenton is quite a drive ) /forums/images/graemlins/smile.gif
   / Renting a 3pt hitch auger "CENTRAL VA" #5
I looked for a while up in PA - not VA I know - but folks around here would only rent me the auger WITH a tractor. Go figure. It was cheaper just to buy one in the end - $400 from TSC.
2016 KENWORTH W900 T/A DAY CAB ROAD TRACTOR (A51406)
2016 KENWORTH W900...
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
2003 500 BBL FRAC TANK (A53843)
2003 500 BBL FRAC...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
Krupp 300 Hydraulic Hammer (A52384)
Krupp 300...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
