I put in a pond a few years back, and the soil from the pond was spread and graded around the pond. Over the years, this has settled and cracked and is now almost impossible to mow without being thrown off the tractor.
Last year I purchased a 2320, and would like to use this to try and fix the problem. From a couple of hours spent reading on this site, I think the answer is either a box blade, or a tiller, or both. I'm leaning toward the box blade, which seems to be a one-tool-does-lots option. So... some questions:
QUESTION ONE - I was told by a landscaper friend that I need to kill the sod first, then scrape it all off (I'm guessing with a box blade), then resurface and seed the area. My question is, if I use the box blade, do I really have to kill the sod first? Can I just use the blade to tear it up and level it all out, and then maybe a landscape rake to remove any remnants of sod before reseeding?
QUESTION TWO - I have a lot of stumps on my property - most in the 6 inch diameter or smaller range. Would you pull these out with a box blade, or is that asking too much of the attachment?
Thanks in advance for any advice.
Bill
Bill
