Removing X728 body parts
   / Removing X728 body parts #1
mikefamig
CT
JD X728
I recently removed the rear fender section and footrest section from my X728 to repair the deck height adjuster. Now in hindsight it occurs to me that I may have been able to just remove the footrest section to do the job.
My question - Has anyone removed the footrest section alone without first removing the rear fender section? Can it be done without scratching up the paint?
TIA, Mike.
I want to add that removing the body parts from this machine was a lot easier than I thought it would be and only had to remove about ten fasteners (nuts and bolts). It's really the way to go if you have to work underneath and I think it's even worth doing once in a while just to clean things up good. You can easily put it back together in about a half hour.
Mike.
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
40ft Shipping Container (A52377)
40ft Shipping...
Light Tower (A52377)
Adams 5 Ton HC Spreader (A53473)
Adams 5 Ton HC...
