Removing the Headliner in a 5010 Cab HST
   / Removing the Headliner in a 5010 Cab HST #1
bobm6996
Greenfield, Indiana
Mahindra 5010 4WD HST Cab, Mahindra 2615 Gear, Scag Tiger Cat 48", Gravely 42" ZTR, EZ GO Gas Golf Cart
Just curious if anyone has tried to remove the headliner or remove the cab top on a Mahindra 5010 HST cab? I am wanting to replace the factory radio and speakers with something better and also wanting to do a couple other things that might be easier if I could see what is inside the liner. There are Phillips screws all the way around on the inside of the cab, but before I attempt this wanted to have an idea of what I might be getting into.
   / Removing the Headliner in a 5010 Cab HST #2
Would it be easier to go in thru the roof?
Brett
   / Removing the Headliner in a 5010 Cab HST #3
Only take the screws (really just a expandable clip) out of the headliner around the hatch. Remove the bolts that hold the roof on, I think there is six. You will also need to remove the hatch and then lift the roof off and will give you access to audio system as well as heat and air. Hope this helps you out.
Thanks, will give it a go in the next week or two.
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
Unverferth Brent CPC PT 16' Disc Ripper (A50120)
Unverferth Brent...
1997 Cat 953C Crawler Loader (RUNS) (A50774)
1997 Cat 953C...
2015 Nissan Frontier S Crew Cab Pickup Truck (A50323)
2015 Nissan...
INOP/NON-RUNNING Chevrolet Rollback (A51572)
INOP/NON-RUNNING...
