Removing sub frame to skid logs
   / Removing sub frame to skid logs #1
liberty2701
Platinum Member
Lakes region,NH
Kioti Dk50se hst
I have a Kioti dk50 that has a backhoe and subframe. The subframe is bolted at two points on the tracter. It is two pieces. One centered and one in the rear. I would like to remove the subframe when skidding logs with my logging winch so I can pick up alot more ground clearance. Some of the terrain is quite rough. Is there any harm in removing the frame maybe once a year and reinstalling it. i am concerned over the longterm about stressing the threaded portion of the tractor by taking the bolts in an out repeatedly.
   / Removing sub frame to skid logs #2
I have the woods subframe for my back hoe. I have yet to have an issue with ground clearance regarding the sub frame. All of my trails are pretty rough with lots of rocks.
I've had the skidding winch touch a few rocks with a load on it but other than that, no issues.
You are right . I a m probably being overly cautious. Just trying it eliminate any chance of catching a rock.
   / Removing sub frame to skid logs #4
The subframe on mine is "sistered" to the FEL frame member so it doesn't reduce ground clearance to any extent. I always figured those gave some protection to the underside and would be the mounting point if we ever wanted to add a skid plate. Unless your subframe really droops way below the underside of the tractor, having it there might keep something from snagging one of the filters, hoses, linkages, etc., which can booger things up in the worst way (that's a technical term, by the way :). If you are doing a lot of log skidding and it's rough terrain, consider the skid plate option to protect the underside.
Good advice. Thanks
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A53426)
2024 TIMPTE HOPPER...
2012 Hyundai Genesis Sedan (A51694)
2012 Hyundai...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
2012 FREIGHTLINER CORONADO (INOPERABLE) (A53843)
2012 FREIGHTLINER...
