Removing sterring wheel from my Kubota
   / Removing sterring wheel from my Kubota #1
banjerpicker
I have a L2850 and a M4700. Both shop manuals call for using the same steering wheel puller...over $250.00(ouch!!!) from Kubota.
Do you have to use one? Or cheaper models that would work from a car dealer, parts house or even a rental place?
I just need some ideas to help get this wheel off so I can get to the front panel wiring.
Thanks Larry
   / Removing sterring wheel from my Kubota #2
Thanks Larry
I've pulled the steering wheel off one of my B5100E's with a Sykes-Pickavant puller, sadly I cant recall whether I used the thee legs or the bearing seperator.
A seperator, if it fits, would spread the strain over a bigger area.
   / Removing sterring wheel from my Kubota #3
I recently pulled the steering wheel off my B7100HST-E and all I had to do was remove the center cap,nut and washer and tapped underneath with a 4 lb. hammer lightly, while pulling up on the outer edge and in a couple of licks, it came right off.I dont know if you have room to get underneath it like that, but mine was no problem. Also I dont see why a regular steering wheel puller, like from a parts store would not work. Also before replacing it back on , put some anti seize on the splines and threads to make it easier next time. Good luck, zman
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
Sears/Craftsman Shredder (A51573)
Sears/Craftsman...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2006 Mack CV713 Granite Dump Truck, VIN # 1M2AG11C36M039886 (A51572)
2006 Mack CV713...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
