Removing starter motor on MF231
   / Removing starter motor on MF231 #1
def38
Platinum Member
woods and mountains of Alabama
M-F 231S
Perkins powered 231S. I need to remove the starter for service and rebuild. Does anybody have a exploded view of the starter motor mounting fastener details? I can't see behind the starter to determine what to loosen.
Thank you in advance.
No loader. It appears that there are three fasteners with the rear innermost one protruding out past the starter case at the solenoid end. The other two are nuts accessible with an open end wrench. But, I want to be sure in case I need some special tool.
Also, I tried removing the rusty steering wheel nut with an impact wrench. Didn't budge. The nut is now completely round. Any thoughts on steering wheel removal?
   / Removing starter motor on MF231 #4
I have a 2001 231s with a loader and I had to replace the starter. It was a nightmare with the loader frame in the way. There were 3 bolts holding the starter on. 2 on the outside that you mentioned and one just like those two is on the back side of the starter. It is a pain to get to. I used a socket and a universal joint and a couple extensions put together to get the ratchet out past the end of the starter. It was a pain but I finally got it out.
   / Removing starter motor on MF231 #5
Check out the Andrew Camaratta starter removal video.
He shows how to do it with a CTL.:laughing:
Thank you Addict...mine is a 2003 made in Turkey...how about yours?
BTW, any thoughts regarding the steering wheel?
   / Removing starter motor on MF231 #8
Yes, made in turkey as well. I bought mine used and the steering wheel center cover was missing. It was rusty in there. I tried to remove the nut to clean it all up. I couldn't budge it so I gave up on it. I didn't really need to take it off I just wanted to. I sprayed alot of penetrating oil in there and ordered a new cover for it from a dealer. My hope was that if I ever had to take it off, the penetrating oil might help.
   / Removing starter motor on MF231 #9
KROIL works far better than most other penetrating oil>
Adams 5 ton Fertilizer Buggy / Wagon (A52128)
Adams 5 ton...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A51222)
2018 FREIGHTLINER...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
