Removing small stumps
   / Removing small stumps #1
dbrauner
Central North Carolina
JD 670
Is there anything I can use to remove small (<4" diameter)? My bucket doesn't seem to do too much. I have a JD 4310 with a 430 FEL. Maybe a subsoiler or something that digs a little?
   / Removing small stumps #2
I have a subsoiler foot with a horizontal cutter wing welded to the bottom of the foot. It's about 10 inches wide with a sharp front edge. It's good for popping out small stumps. A plain subsoiler will help loosen the stump but the winged subsoiler usually gets it out on the first pass.
Gabby
   / Removing small stumps #3
The best way I've read to remove stumps (sans big backhoe) is to secure them with a heavy chain, then run the chain over a pickup rim so you get a straight up pull, then hook it to your drawbar (nothing higher than that or you risk rear rollover). Put a load of dirt in your FEL to give you more traction.
Many times when I have stuff like this to do, I put Mrs. Bota on the tractor and I do all the chain work. I stand right next to the Bota to make sure she stays safe.
Oh, impress your neighbors by not shouting at each other. We use simple hand signals both tractoring and sailing. Works great. Mostly, it's hard to shout using your hands!
That's what I'd try anyway.
Ron
   / Removing small stumps #4
Hey Ron,
Increase traction by filling the bucket? That one threw me, but I guess it's because none of my tractors have fwd.
Gabby
   / Removing small stumps #5
Uh, well I assumed you had 4WD.
You got me there bud!
Ron
   / Removing small stumps #6
</font><font color="blue" class="small">( Is there anything I can use to remove small (<4" diameter)? My bucket doesn't seem to do too much. I have a JD 4310 with a 430 FEL. Maybe a subsoiler or something that digs a little? )</font>
Toothbar will help you greatly...I removed bigger stumps with a smaller tractor..the toothbar help me dig around the stump, and break the roots...the rest was easy
Duc
   / Removing small stumps #7
Gabby,
Do you happen to have a picture of this "winged subsoiler", or can you find one? I like the sounds of it, but don't think I've ever seen one.
Jim
   / Removing small stumps #8
Sounds a lot like a middle buster to me. /forums/images/graemlins/wink.gif
   / Removing small stumps #9
Is this the "puppy" that you are talking about?
   / Removing small stumps #10
Or is it this one?
2012 KENWORTH T800 (A50854)
2012 KENWORTH T800...
2008 MAGNUM LIGHT PLANT (A50854)
2008 MAGNUM LIGHT...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
1265 (A50490)
1265 (A50490)
2020 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2020 KOMATSU...
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
