Removing rear wheels on b7100
   / Removing rear wheels on b7100 #1
grandv8
I know this sounds like a stupid question, but to remove rear wheels is it acceptable to just remove the wheel with the hex flange attached to the wheel by removing the pin and loosening the set bolt and pulling them offf, or do you need to unbolt this flange from the rim? I just know that this wheel design on these isnt the greatest so I dont want to screw anything up
lol, I think I was overthinking it. I do have a small amount of play on the right side. I will need to add a few thin Brass shims once I get my new Ag tires installed and ready to remount.
   / Removing rear wheels on b7100 #3
Sounds like you have the old style hubs. There is a newer much much better version out.:D
please post a link to the new style hubs if you would be so kind sir............
   / Removing rear wheels on b7100 #5
Can't post a link but you could call your dealer.:D
LMC LOT NUMBER 144 (A53084)
LMC LOT NUMBER 144...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
1989 Freightliner Cabover FLA086 (A53472)
1989 Freightliner...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
