Armymutt
I'm trying to remove the pinion from my 135. I've removed the 6 bolts holding the housing and threaded two back in to extract it. The housing is loose, but the pinion won't budge. Do I need to lift up the rear end to rotate a wheel in order to free it? The service manual doesn't mention this, but I can see that it is engaged in the ring.
