Removing differential lock lever spring pin
   / Removing differential lock lever spring pin #1
docmx
I have a M4900 that is leaking oil from the oil seal located on the differential lock shaft. Want to replace it but can't seem to remove the lock lever spring pin. Anyone have an idea how to get this out? It is a hollow aluminum pin that is seated flush to the lower and upper side of the lock lever. Having a difficult time finding anything of correct diameter to pound it out with a hammer. Everything I've tried from punches and screw drivers do not budge it.
Found what I need...roller pin punch. Didn't know there was such a thing!
2017 Makita HM1307CB 35lb Demolition Hammer (A49461)
2017 Makita...
Club Car Electric Golf Cart (A48082)
Club Car Electric...
New/Unused 2 Post Car Lift (A48837)
New/Unused 2 Post...
2017 DB800XL Dual Dustless Blaster Trailer with Rotair 425CFM Compressor (A48837)
2017 DB800XL Dual...
UNUSED LANDHONOR 20,000# ELECTRIC WINCH (A50460)
UNUSED LANDHONOR...
(APPROX. 100) 24" X 85" EXPANDED METAL (A50459)
(APPROX. 100) 24"...
